Hi Ryan
I'm not quite sure what you mean by Program the Manual Playbacks Like Submasters. Can you try and clarify this a little.
The User Defined Faders (the top bank) can be programmed with Channel Data, in which case they will act similarly to submasters. The bottom bank of faders (Playbacks) are individual cue stacks and as such are more akin to the Playback X area of the Frog range.
Peter Kirkup
Hi Ryan
There are lots of ways to record a cue stack, however the simplest is to use the syntax RECORD <stack number> / <cue number> ENTER.
Another option is to click the SELECT button above the playbacks, then just use RECORD ENTER to append a cue to the end of the current stack (if no cues are programmed, cue one is created when you perform RECORD ENTER).
Hope this helps
Peter Kirkup
