ryandell Posted May 4, 2006 Report Posted May 4, 2006 playing on the new phantom frog program just wondered how if i can programme the manual playbacks like submasters is this possible Quote
Kirkup_xp Posted May 4, 2006 Report Posted May 4, 2006 Hi Ryan I'm not quite sure what you mean by Program the Manual Playbacks Like Submasters. Can you try and clarify this a little. The User Defined Faders (the top bank) can be programmed with Channel Data, in which case they will act similarly to submasters. The bottom bank of faders (Playbacks) are individual cue stacks and as such are more akin to the Playback X area of the Frog range. Quote Peter Kirkup
ryandell Posted May 6, 2006 Author Report Posted May 6, 2006 it was the bottom bank how do i make the cue stacks ???? thanks for your help Quote
Kirkup_xp Posted May 6, 2006 Report Posted May 6, 2006 Hi Ryan There are lots of ways to record a cue stack, however the simplest is to use the syntax RECORD <stack number> / <cue number> ENTER. Another option is to click the SELECT button above the playbacks, then just use RECORD ENTER to append a cue to the end of the current stack (if no cues are programmed, cue one is created when you perform RECORD ENTER). Hope this helps Quote Peter Kirkup
ryandell Posted May 6, 2006 Author Report Posted May 6, 2006 yes thankyou very much for your time Quote
ryandell Posted May 8, 2006 Author Report Posted May 8, 2006 wow got the hang of it now, its good how there is 20 stacks in one fader.The naming of the playbacks is easier than the fatfrog's naming of submasters thanks ryan Quote
