simschr Posted April 10, 2006 Report Posted April 10, 2006 I am using a Alphapack 1 into a Demux 48 and want to know how to control it with an Diablo. I have tried patching it up through the generics key but this has failed to work. Can anyone give me any quick guidelines on how to run this setup? Chris Quote
Paul Posted April 10, 2006 Report Posted April 10, 2006 Some ideas... On the Diablo, check the 'DMX' screen in View/Preview to see what the Diablo is actually sending on each DMX channel. On the Demux, make sure the 'Data Received' LED is lit. Try clearing the the Demux to default (details in it's manual) to make sure you're at a known starting point with no funny laws etc. On the Alphapack, make sure the Channel 1-3/4-6 switch is in the position you require. Quote
simschr Posted April 10, 2006 Author Report Posted April 10, 2006 I soon replaced the 10m 8pin-din cable which resolved all of these issues. Many thanks for you time, It was much appreciated anyway. Chris Quote
