These are still available.
Depending on what version of the desk you have the codes are as follows.
0011500 for the Mk1 desk
0011600 for the Mk2 desk
Please contact your local dealer to purchase one.
Keith Rogers
  • 7 months later...
I have inherited an Alcora desk linked to Chilli dimmers. I am in the process of plotting the school nativity and the school panto and I'm running out of memory slots fast! Any way I can increase the memory of the Alcora or store info externally? Any help would be greatly apprieciated.
HI
You can use an external memory store. This will allow you to save your show up to say interval and then reload the second half. The memory stores are designed for use with this Alcora or Elaras. You will be able to get one from your friendly local Zero 88 dealer.
Only info you will need to have is if it is a mark 1 or mark 2. If it is Grey, mark one, if it is Blue Mark 2.
Best
Graham
