Can your Chilli dimmers......
Looking at buying aprox 100+ ways of chilli dimmers :D but is there any way to set them to no dim, so that i can power moving lights? or we might be getting some install 6 can they do this???
I need a new job
Yes you can set Chilli or Install6 dimmers to a Switch Law, but it's not recommended to use this to power moving lights (see THIS POST). Have a look at the 'Chilli Pro 1210 Switch' (spec sheet HERE) for powering your moving lights. Just like a normal Chilli dimmer, but instead of triacs, you get heavy duty relays. Controllable from Chillinet or DMX like every other Chilli dimmer.
Rack 6 it is then, i wanted to remove the patch bay and have nice, tidy, chili dimmers. But no...... im stuck with 100+ patch bay.....ahhhhhhhhhhhhhhhhhhh
I need a new job
