Revenant Posted March 21, 2006 Report Share Posted March 21, 2006 hi everyone. i want to programm a simple Knight Rider chaser. when i programm a chaser with a few paar-light, i put the Ch.1 to 100% and press "programm" than i put it back to 0% and the Ch.2 to 100%, but the Ch.1 doesn't go to 0%, it means it is still 100%. when i start the chaser CH.1 goes up to 100% then CH.2 goes 100% but CH.1 doesnt go down to 0%. the problem is there was i time it worked, but now it works not. there are some chaser, and they look like they should, but these one i wuld programm now are working not. so it must be a user fault, but i don't no what i am doing wrong. PLS help me. Quote Link to comment Share on other sites More sharing options...
K-Nine Posted March 21, 2006 Report Share Posted March 21, 2006 When you are programming a chase memory, ensure that the Playback X Master fader is at zero, otherwise you will be outputting the previously programmed step. When running the chase, remember to put the playback X master fader back to full. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Revenant Posted March 25, 2006 Author Report Share Posted March 25, 2006 thx, if it works, i will post now reply. mfg Rev from Ger Quote Link to comment Share on other sites More sharing options...
