Jean-Pierre Potvliege Posted March 14, 2006 Report Posted March 14, 2006 How should I connect the DMX out from the dimmer ? It's no documented in the manual Quote
Paul Posted March 14, 2006 Report Posted March 14, 2006 Page 2-4 of the Chilli Dimmer Manual (Issue 6) - DMX Connection - this should be what you're looking for. Quote
Jean-Pierre Potvliege Posted March 14, 2006 Author Report Posted March 14, 2006 Sorry Paul but the manual speak only of the DMX input and I need to connect also the DMX output because I have to daisy chained the dimmers ! DMX input is connected through a 4-way screw terminal block located on the control PCB (Figure 2-9). Quote
Franck Posted March 15, 2006 Report Posted March 15, 2006 DMX IN & OUT are on the same 4-way terminal block. Regards Franck Quote
Jean-Pierre Potvliege Posted March 15, 2006 Author Report Posted March 15, 2006 Thank you for you prompt answer Regards Quote
