dannyp200 Posted February 27, 2006 Report Share Posted February 27, 2006 When assigning wheels to parameters, thumb and second finger are swapped over when loaded onto the illusion. Is it possible to assign channels to wheels without using fixtures. ie a RGB,LED par needs it's colours to fade with the Masters, so it's not a COLOUR parameter, but you are only allowed 1 brightness parameter. Quote Link to comment Share on other sites More sharing options...
KWR88 Posted February 27, 2006 Report Share Posted February 27, 2006 What type of fixtures are you using, is it only the colour attribute or is it beam shape as well? For the second part of your question no it is not possible to do this directly as you can only have a single dimmer channel for a fixture. There is something that you could try, it is a little complex to try and explain here and again I would need to have the type of fixture you are using. please contact me for further details. Illusion Reference 4769 - parameters assigned to wrong wheels Quote Regards, Keith Rogers keith.rogers@signify.com DD: +44 (0) 1633 833 101. Link to comment Share on other sites More sharing options...
Paul Posted July 1, 2008 Report Share Posted July 1, 2008 The wheel group loading issue has been addressed in Illusion500 Version 1.8. Quote Link to comment Share on other sites More sharing options...
