parameters assigned to wrong wheels
dannyp200
When assigning wheels to parameters, thumb and second finger are swapped over when loaded onto the illusion.
Is it possible to assign channels to wheels without using fixtures. ie a RGB,LED par needs it's colours to fade with the Masters, so it's not a COLOUR parameter, but you are only allowed 1 brightness parameter.
What type of fixtures are you using, is it only the colour attribute or is it beam shape as well?
For the second part of your question no it is not possible to do this directly as you can only have a single dimmer channel for a fixture.
There is something that you could try, it is a little complex to try and explain here and again I would need to have the type of fixture you are using.
please contact me for further details.
Illusion Reference 4769 - parameters assigned to wrong wheels
Keith Rogers
  • 2 years later...
