Hi @ all
I'm searching for an fsoftware for the Coemar Pro Spot 250 Evo fixture.
The newest libary only includes software for Pro Spot 250 LX.
-has anyone the software for this partiuclar spot?
-or can I use the other the one?
I hope that anyone can help me
thanks in advance !
greetz from germany
lifex
Hi lifex
I've created a fixture profile for the ProSpot250 Evo and added it to our main library, so it will be included with the next release. For now, please use the attached fixture profile.
Let me know if you have any problems with the file.
Hi Kirkup
unfortunately the fixture doesn'T work properly !
Pan/ Tilt work
Dimmer also works
Colour works
but
Beamshape ist not working
the prisma effect doesn't wprk
the other effects like gobo rot I couldn't check, because gobo function is not working.
Maybe you can help me again, because tonight is the event, and i have to fix it !
I found an DMX addres sheet of the ProSpot 250 Evo
http://www.coemar.it/cgi-bin/prodotti/docu...0Evo%20dmxE.pdf
I hope you can help me !!!
Hi Lifex
I've double checked the fixture profile I uploaded and it matches the DMX profile provided by Coemar.
Are you using the fixture in 8 or 16 bit mode?
In order to get the Prism to work, you need to set the FX1 channel to a value between 96 and 156, then set the Prism channel to rotate the prism.
When you say that the gobo isnt working, what exactly are you doing to try and get the gobo into the beam. If you select the Gobo1<> parameter and wheel the value up, the gobos should enter the beam. To set the rotation and indexing, use the G1 <<>> parameter.
Let me know if you're still having problems and i'll look into this in more detail. Its possible that the DMX profile on the Coemar website is wrong - we've had this experience before - in which case, it would be best for you to address the fixture to 1, and write down the control channels from the generic faders. I can customise the profile if you let me know the problem channels.
Peter
Hi Kirkup
first of all I now change the desk from a leap frog to a fat frog.
I'm using the spots in 16bit mode.
The FX 1 works, but its some kind of a templates, with prism and beamshape +rotation...
I'll let you know....
