Jester Operating Software version 1.6 has been released, and is available for download from the Zero 88 support website. CLICK HERE.
This contains the following changes from version 1.5:
  • * French language help text added. Use the 'Help Language' menu in Super-User to set the language for the on-line help.
    * When naming memories, submasters or shows, pressing a different letter button will now immediately advance the cursor before typing that letter.
    * The problem of submasters outputting from the wrong page (introduced in version 1.5) has been corrected.
To update the desk:
1. Download the zip file, and extract the contents to a USB memory stick. This will be a file with the extension .jos. It is important that you only have one .jos file on the USB memory stick at any one time.
2. Plug the USB memory stick into the desk.
3. Switch on the desk with the Left and Right cursor keys held down. The Jester Upgrade Menu will appear on the LCD and monitor screen. The monitor screen is quite distinctive - it looks like a red and yellow circus tent.
4. Wait for the USB memory stick to be recognised by the desk. This is usually indicated by the LED on the memory stick flickering for a short time, and then returning to a steady flash.
5. With the cursors flashing on <OK>, press the Enter button. When the desk displays the name of the upgrade file found, ensure <OK> is selected and press Enter again to begin the upgrade.
6. The desk will now perform the upgrade. Do not switch off while this is happening.
7. When the upgrade is complete, press Enter to start the desk, there is no need to switch off and reboot.
This topic is now closed to further replies.
