larsinge Posted January 30, 2006 Report Share Posted January 30, 2006 Hello. I have a question about editing a memory on a Fat Frog. If I only want to adjust a pan function on one fixture, and wanting all other fixtures to be left as they are in this memory, how can I do this? If I edit it now, I have to edit one parameter on all fixtures, or they lose their programming, and goes to stand by value. Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted January 30, 2006 Report Share Posted January 30, 2006 Assuming you're running the latest software, the quickest way to do this would be... Press MEMORY Select the memory you wish to edit Press EDIT Use the fixture select buttons to select the fixture you wish to adjust. This may involve deselecting other fixtures. Adjust the parameters as required Press EDIT The desk will prompt you to update changes... select Yes Problem solved Hope this helps Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
