Hello, i've been trying to program lighting scenes into my leap frog console and ran into a bit of a problem. I have 42 par cans that i'm trying to program and everything seemed to be going fine. but then when i switched from one submaster to the next, my colorpros reset to a different color, and my technobeams moved position?!! obviously thats an issue. I tried programming on a virgin submaster page, with the technobeams and colorpros totally off, and still got the same results. i'm pulling my hair out over this. thanks!!!
The age old question once again - Is the desk in full or partial mode ?
If the desk is in full mode - all generic channels and all fixture parameters will be recorded onto the submasters regardless of whether you have set or changed any of their parameter values. When you raise the submaster the fixtures will go to these values.
If you wish that submasters only affect the fixtures that you specifically program into the data or transferred memory then the desk must be in Partial Mode.
