gatto Posted January 16, 2006 Report Share Posted January 16, 2006 Hi! I'm using a leap frog and i'd like to program only the strobe in a submaster. How can I do that, without programming the other beamshape parameters? Thanks, Stephane Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted January 16, 2006 Report Share Posted January 16, 2006 Set the desk into Partial Mode, ensuring that Beamshape (under SuperUser->DeskSetup->ProgramMode) is set to <Channel>. Now, select your fixture and set the shutter/strobe to the rate as required. Now hold down WHEELGROUP and nudge all of the other beamshape parameters, until they read "---" on the LCD. This indicates that they are not tagged and therefore will not be programmed. Now, record the submaster as normal. The data will be recorded and when you raise the submaster, the strobe should trigger to the level it was at when you set up the submaster. Note that this is a single level only, and you can change the trigger level via the Submaster screen. HTH Quote Peter Kirkup Link to comment Share on other sites More sharing options...
tygrysm Posted January 16, 2006 Report Share Posted January 16, 2006 Be sure you have 10.x version of firmware Quote Link to comment Share on other sites More sharing options...
gatto Posted January 16, 2006 Author Report Share Posted January 16, 2006 Thanks for the quick answer. Have a good day, Stephane Quote Link to comment Share on other sites More sharing options...
