  • 2 months later...
Derrick. If you are like me you tried this setting and it did not work? This is caused by older Martin kit having the DMX signal the other way around. This tends to mean that it kind of works but the parameters are all over the place. If you have been using a Martin controller up to now, then the problem will not have risen! When I got my four Robocolors the seller produced the polarity change leads!
Hope this helps
Nick
