lxkev Posted January 12, 2006 Report Posted January 12, 2006 You can only save/open to cd or flash. Why not on the pc? Quote I need a new job
Kirkup_xp Posted January 18, 2006 Report Posted January 18, 2006 At the moment, Phantom Frog2 is a port of the desk software, so the hard-drive isn't allowed as an option (because it isn't on the desk either). I believe there have been discussions about allowing you to map a path to a directory on your pc, as you can with Phantom Frog at the moment. Quote Peter Kirkup
DSA Posted May 24, 2006 Report Posted May 24, 2006 Hi, Is there any update on this issue? It is really quite annoying, as my PC has already allocated F: and G: to a card reader, and so any flash drives get the label H:, which cannot be read by the Phantom. Yes, I could change the label on the reader over, but I don't really wan't to do that! Thanks, David Quote
