Pipo Posted August 31, 2003 Report Posted August 31, 2003 1) is it possible to make the pallets work stand alone? -->what i mean is that when you lock the pallet-screen, it should be possible to select the required color or position without pressing the attribute-button. 2)when you have, lets say, 4 moving-chases selected on your sx-buttons, then is it possible when you desellect them it goes automaticly to the previous one? 3)overlapping memories -->when you have a few positions programmed on your pallet and you have a simple position-chase(going up/down) then would it be possible to make the chase work on every position programmed in your pallet by just selection the position when the chase is active? Quote Den Pipo Pro Light Design
Paul Posted February 25, 2004 Report Posted February 25, 2004 1) Palette-lock functionality was added in release 9.0. See the release notes for details. 2) This would require the desk to keep a history of data sent to LTP outputs, rather than simply keeping the last value which is what it does now. Big re-write of internal memory structures etc! 3) Movement effects are now recorded in position palettes (release 9.0). However since you can't currently record a movement effect separately from it's centre position, the overlap effect you describe cannot currently be achieved. Quote
