Chases cannot be recorded directly to the submasters, due to the memory structure of the Frogs. In order to have a chase on a submaster, first record it as a memory. Then select the memory and press TRANSFER NO TIME (or TRANSFER WITH TIME, depending on whether you want a fade time on the submaster). Now select the submaster you require and press ENTER.
To make a chase loop, set the 'shots' to 0. Any higher number of shots will set the chase only to run that number of times.
HTH
