How do you daisy chain 3 (analogue) alphapacks into a Level 24 board? Having never used a Level 24 until tomorrow the simpler the instructions the better!
Also, is it possible to obtain channel Fuse holders for Alphapacks from Zero88?
Thanks!
Hi Rob,
The answer to both of your questions is yes.
To daisy-chain the packs, simply link them with standard analogue cables (there are 2 sockets per pack). The switch on the bottom of each alphapack will set whether it uses channels 1-3 or 4-6 from it's input. To get separate control of the third pack (if you don't want it sharing the same 3 channels as the one of the first two packs), simply run another analogue cable out from the desk.
If you need to buy replacement fuseholders, just give us a ring!
Paul.
