Hello my friends.
I'm having a small problem running my movingheads in 16bit from my FatFrog. Is it possible that FatFrog can't do this? 8Bits works just fine.
- Leo
The Fat Frog can do 16-bit no problem. You need to make sure that the mode that you have set the fixture in matches the fixture personality that you have selected on the desk. In most cases, changing a fixture from 8 bit to 16 bit control affects it's DMX channel allocation, hence the need to ensure that the settings at both ends of the DMX match.
I thought the movingheads was in 16bit-mode but it was just a menu.
When i selected "16-bit" i was able to choose "mode1" or "Mode2".
Sometimes it´s quite easy ;)
Tnx for your help.
