Hi there
I am in need of some help with what must be a very simple problem.
All I want to do is plot a chase from a sub onto a memory. All the memory contains at the moment is the step that the chase was at when I hit the program button.
There must be someone out there who can help this idiot in distress.
Cheers
you are not able to record the chase from a submaster back into to a memory. you would end up with the info for the point where you pressed record not all the steps.
Keith Rogers
