dogcop Posted November 22, 2005 Report Posted November 22, 2005 Morning Forum, Here's my next problem that hopefully someone can come up with an answer. I am trying to assign the abstract futurescan 1CE scanner to the desk and I am trying to run four of them. I have loaded the attribute data ok from floppy and have patched them in at channel 220. Again this is ok. I have plugged the scans in to the desk and their green light comes on to show it is receiving dmx ok. Now these scans have those damn infernal dipswitches which having done loads of research I have come to the conclusion that channel 220 dmx = switches 3,4,5,7,8 The scans just don't respond at all when I fixture select them. Has anyone any ideas what the problem maybe. I'm guessing its something really obvious but not to me !!!! :oops: I have also tried them by patching into channel 1 and having dipswitch no 1 selected with one scan and not a chain of four. Again no joy help / thoughts appreciated Andy Quote
Brian Posted November 22, 2005 Report Posted November 22, 2005 Well your DMX maths is OK. I've had problems in the past using 'accessibly priced' units where the DIP switches work 'the wrong way round' ie ON = '0' and OFF = '1', or was is the other way round. I'd try inverting the logic in your switch settings. Quote ex-Leap Frog Owner, ex-Mambo Frog Owner, ex-XLS Owner, ex-Alcora Owner, ex-Elara Owner Owner of a big pile of Betapack 2s Bozone (n): The substance surrounding stupid people that stops bright ideas from penetrating. "Am I dreaming this?" "No, and you ain't in Kansas neither." "Longbottom's been neglecting his ear muffs."
Pinspot Posted November 22, 2005 Report Posted November 22, 2005 Check the DMX polarity, as the green LED can sometimes light when the DMX is inverted. Quote
dogcop Posted November 23, 2005 Author Report Posted November 23, 2005 thanks for the ideas guys I'll give them a try Quote
minimac Posted November 23, 2005 Report Posted November 23, 2005 yea you will need to put a phase converter in, as abstract swapped the pins round. presumably so you only use there controllers. i did have the same prob Quote
severino Posted December 29, 2005 Report Posted December 29, 2005 yes, the abstract use 1. gnd 2. +data 3. -data how a audio signal.. Quote
