philby Posted November 7, 2005 Report Posted November 7, 2005 Hi New user to the Alcora board and I've read the manual from cover to cover - but can't find a way of editing a stored scene (or sequence) memory whilst in run mode. I know I can edit in program mode but this is more for last rehearsal adjustments once the scenes are programmed. If I'm looking at a scene and want to punch up a channel by 2 stops on the current cue, I want to be able to directly edit that channel and save the resulting changes - I don't want to stop run, revert to program, make the changes and frantically key back to the last memory location! There's got to be an easier way! Is there? Many thanks in anticipation Quote
K-Nine Posted November 7, 2005 Report Posted November 7, 2005 The Alcora has distinct modes of operation (Preset, Program and Run). If you want to edit an existing memory (scene or sequence) then you need to be in Program Mode to do it. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
