JAdamson Posted October 28, 2005 Report Posted October 28, 2005 I am researching the feasibility of using a Fat Frog in a primary/middle school scenario. I am using a majority of conventional instruments, but also have some basic intels for color changes. Given that these students may not be entirely consistent about remembering their blocking, I may need to add "live" looks 'on the fly'. If I were in the submaster playback mode, would I be able to just go to the 'Scene A faders' and bring up the needed light--or are there keypresses I would need to do? Note that I am not trying to rewrite the cue. This is for a "1 time" temporary look only. Thanks for your responses-- John A Quote John Adamson
Paul Posted October 28, 2005 Report Posted October 28, 2005 The Frog doesn't have a "submaster playback mode" as such. There is one operating mode, in which any combination of the channel preset faders, submaster faders and playback x (memory stack) can be used together. So yes, you can at any time during the performance just add light using the channel preset faders. Quote
Frog Genius Posted October 29, 2005 Report Posted October 29, 2005 The Frog doesn't have a "submaster playback mode" as such. There is one operating mode, in which any combination of the channel preset faders, submaster faders and playback x (memory stack) can be used together. So yes, you can at any time during the performance just add light using the channel preset faders. Not being rude but I think he said FatFrog, but you might mean that. There is the FROG function - the FatFrog works with Scrollers/Colour changers, its easy to use - and remember (and some of the lx guys at my school are pretty thick)(<<not me). There is also a PlaybackX- you can add in any channels you like while you are "playing Back". There is a chase mode and a kindof standard mode(cant remember what its called) for programming but as with the frog only one playback mode. However you can play cues using presets A and B aswell. Wait for the info to come flooding in- oh and welcome to the forums, I hope you find them helpful and informative! GOGS Quote
