Submasters after a software update
Guest Rob Oxlade
Hi Folks,
Been using a Fat Frog for three months with original sofeware. Fantastic desk! Then I upgraded from release 5 of thereabouts to 8.01. Fine, great new things to play with... BUT one thing I used to do was leave one sub up with moving fixtures at full then press the bump buttons to change colour and movement. Colour is fine but when I move to another movement sub the movers all move to a start location before moving, and this happens each time I change the fader/bump button. It didn't do this before, the movers would catch up with the new sub.
Also when using the SOLO flash feature, all the subs that are on, from any page will unload and all subs from the page selected come back on this is very anyoing and doesn´t happen with BLACKOUT.
Any ideas,
regards, Rob
Dear Sir,
This is probably due to the addition of an LTP trigger level.
You should try and turn the LTP trigger off in super user/set up desk defaults.
