kevlawrence Posted October 8, 2005 Report Share Posted October 8, 2005 The display of the fixture brightness on the monitor is a great idea - however this does always seem to reflect what is actually on. I currently have 7 fixtures on a leap frog patched to fixtures 2, 4, 6, 7, 12, 15 and 21. But only the first three regularly give their brightness on the monitor. Quote Link to comment Share on other sites More sharing options...
ice Posted October 9, 2005 Report Share Posted October 9, 2005 First of all: what a weird way of patching! Second: I don't get your question? You can alter the fixtures you're viewing by pressing F1 and a fixture selection button, the button you press will be the first fixture on the screen. It works fine for me, don't see your problem. Maybe you could explain a bit? Quote > 500 posts, time for a new T-shirt? Link to comment Share on other sites More sharing options...
kevlawrence Posted October 9, 2005 Author Report Share Posted October 9, 2005 The patching is used so that each row of fixtures buttons matches a lighting bar on stage, weird but it works for me!! What I didn't explain was that I was referring to the memories page, which now shows (or should do) the brightness level of all fixtures - this is the bit that seems to work when it feels like it!! Quote Link to comment Share on other sites More sharing options...
Paul Posted October 9, 2005 Report Share Posted October 9, 2005 The 'FIX BR' bar at the bottom of the memories screen shows the levels of the 'virtual presets' that are controlled by the wheels for the fixtures. These are mixed HTP with other brightness sources (e.g. submasters and playback stack), and so aren't necessarily the same as the current outputs. Have a look on the outputs screen if you want to see the current outputs. See also THIS TOPIC. Quote Link to comment Share on other sites More sharing options...
ice Posted October 9, 2005 Report Share Posted October 9, 2005 Useful when some light stick to being on all the time and you don't know where that output is coming from. Check your screen and make sure those virtual faders are at 0! During showtime these should always be set to 0, at least thats the way of running the show that I like. Use a submaster for brightness of your fixtures. Quote > 500 posts, time for a new T-shirt? Link to comment Share on other sites More sharing options...
