russ1669 Posted September 28, 2005 Report Posted September 28, 2005 I was thinking about using a linebacker to run a simple sequence in a fixed installation, but I just noticed that in the user manual it says the unit reverts back to the main menu if power is interrupted. Does this mean that the sequence will be aborted? and if so are there any other low cost controllers that would restart the sequence on power on? Russell
KWR88 Posted September 29, 2005 Report Posted September 29, 2005 Hi Russell, Not sure but I think I may have already spoken to you about this. If you are running the LB as a stand alone sequence player then it will start of the sequence when the power is switched off and back on. You you can get it to start from where it left of or from step 1 using the superuser option. Regards, Keith Rogers Zero 88 Support: support@zero88.com
