wave
Martin
You can use the effect generator to create a wave, using offset in a fan mode. You can't set it to run just once, if you really need that behaviour you need to program a chase containing a position wave but thats a lot more work. You could try using the memory stack:
mem 1 = empty, fades into mem2 on "go"
mem 2 = wave from shape generator, fades into mem 3 after x.x seconds, as long as your wave takes to finish
mem 3 = empty again.
Not sure if that would give you exactly the effect you need, but you could try.
You could do this using an N-shot chase.
Step 1 - all fixtures at 'home' position
Step 2 - first fixture beginning wave
Step 3 - next fixture joins in wave, first fixture further on in the wave
Step4....n
Step n - Last fixture finishes wave
Set the chase to run once (Shots: 1) and modify the speed and attack as required. Transfer this memory to a submaster, and whenever you raise the submaster, the wave will happen :)
But with a decent number of fixtures you have 2 possibilities:
- simple chase with ugly movement
- complex chase which is gonna take a lot of time programming :)
Create 3 position pallets: "top" "middle" "bottom" and use these for programming, that's gonna save you a lot of time.
