Hi
I found a way to change the speed of my chases, live during a show.
I simply bought a Boss DB88 digital metronome, and connected the output to the sound input on my fatfrog.
Now i can change speed using a dial or i can tap the tempo. It also has a loop function so i can trig the chase a desired number of times. In tap mode i can also run the chase manually.
The only negative thing about it (for some users maybe) is that the chases have to run in "bass" mode, so they will all run the same speed...
But for disco, it is great, i think.
Hope you can use the trick.
Morten Mortensen
  • 6 months later...
