We have new strobope EUROLITE DMX superstrobe 2700 and desk Illusion 500 sw ML 1.7. I have some small problem. Strobo without DMX working properly. Strobo controled via desk working oddly.
Strobo have 2 channels - flashrate and intensity, 13 flash/sec max.
When I set both channels on 65% (for example) and I don't touch desk flashes are "in-periodically" - it's looking like very bad random. Intensity fluctuating also.
One from some flashes missing ("strobo is tired and must rest") and later 2 flashes consecutive are faster ("strobo must reach what was skiped").
This error shows between 40 and 100 % of flashrate and all range of intensity. DIP SWITCH 50/60 Hz was OK - 50 Hz.
Why am I writeing on illusionsupport?? I tryied control strobo via another desk (Pulsar Masterpiece 108) and strobo worked properly.
Where is problem?
1) DMX version incompatibility (we know more version of DMX - 1986, 1990, 1998 standartised)
or
2) Some "small thing" in setup?
or
3) Small bug in SW?
or
4) Strobo and Illusion desk are on different powers (different phases) - could it be source of problem? (but I think if DMX OUTs are isolated diffent powers cannot be problem)
or
5) HTP versus LTP ? Problem is allways - in memories, on submasters, in program window.
or
6) Another?
Please can you help me? I don't know what I have to do.
Sorry for my poor english
avolansky
Are you controlling the strobe via two dimmer channels or as a fixture with two channels ?
If via dimmer channels - then both of the strobe channels will be processed as HTP by the desk which may, or may not be what is required.
If via a fixture type - need to check what attribute the the two parameters are assigned as - if brightness it will be processed HTP, if colour/beamshape or position it will be processed as LTP.
I control strobo via dimmers channel because in fix lib 13 I was not found equipment with one dimmer and one other feature (color, beamshape, position). If you know some suitable equipment for this strobo, please tell me and I try and I vill let you know. Thanks for interest of my problem.
avolansky
