IanGLS Posted July 16, 2003 Report Share Posted July 16, 2003 Hi, Excuse me if this has already been posted here. Have just upgraded one of our frogs (fatfrog) to 8.1 and have noticed that when a pallette is created for the first time it seems to take ages. To clarify the situation - you hold down say the colour button and press and hold the flash button where you want the pallette to end up. Previously the screen would change after maybe 2 seconds to the prgram pallette screen where you can progrram clear or cancel. This now seems to take ages - i got bored after a minute and started repeatedly pressing the flash button and it turned up! If you then change the value and attempt to reprogram the same pallette it comes up instantly. Anyone help? As it stands the net effect is that it takes ages to do your pallettes!! Cheers, ian Quote Link to comment Share on other sites More sharing options...
IanGLS Posted July 16, 2003 Author Report Share Posted July 16, 2003 :oops: ah - ok - i just figured it out!! The menu no longer pops up when you create a pallete.... ok - sorry bout that! :oops: Quote Link to comment Share on other sites More sharing options...
K-Nine Posted July 17, 2003 Report Share Posted July 17, 2003 This was a subtle modification that we added into Version 7.5 of the Frog Series software. The popup window and additional key press(es) were removed from the situation when the user programs an empty palette or fixture group, to make programming simpler and quicker. :idea: The popup window only appears when you select a programmed palette to allow the user to overwrite or clear it 8) Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
