After I EDIT LIVE a memory, when the SAVE is done and the PW closes, if I use mouse click to select another cue sometimes the newly selected cue runs.
I've just finished programming a show where there are many queues which have multiple follow on AUTO cues - for example 61 will be automatically followed be 61.2 then 61.4 then 61.6 etc. This might be significant - I THINK it mostly happens when I select the last section of the multi memory cues. It might also be the case that I click to select another cue quickly after the PW closes - it might be within the normal "running" time of the cue I just edited.
I was always using the mouse to select the cue I want next and I don't generally click on the memory number itself - just click anywhere on the line in the memories display - usually in the information field - because that's what I'm using to identify which cue I need to go to.
The "spurious" GO doesn't happen every time but is there any reason why the newly selected cue might run in this way.
Lee Stoddart
It may be that the cue you are clicking on is an Auto cue and as soon as the current cue completes, the next cue (auto) will run.
I would need to set up a desk and experiment to verify this possible explanation.
Bran Media | Myspace
