In the Pallete section of the Program window I have found that selecting a Fixture then clicking a palette does not always highlight the pallette.
By returning to the appropriate Attribute section (Position for example) I can see that the pallete is correctly selected - Parameters show as P02
Lee Stoddart
You are quite right and we have already spotted this :)
As the problem is mainly with the visual feedback on the palettes screen rather than with the actual referencing or output of the palette, it was decided that this should not delay the release of the moving light software.
This problem appears to occur when only some of the fixture's parameters are programmed in the selected palette, or if in the combination of selected fixtures, only some of the fixtures are programmed in the palette. It also depends on whether the Primary Fixture is partially or fully programmed in the selected palette.
Illusion Reference No 4732 - Program Window - Palettes.
