Carl Ehrhardt Posted November 3, 2003 Report Share Posted November 3, 2003 I am not sure if it has been listed somwhere else already... if not: here is a bug: :cry: if i name a submaster it doesn't save the information. As soon as i have switched off the desk and switch it on they are no more there. also if i save the show on a disk it doesen't come back unfortunately. Hope you can fix it :wink: Greatings Carl Ehrhardt Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch Link to comment Share on other sites More sharing options...
KWR88 Posted November 3, 2003 Report Share Posted November 3, 2003 First is it only the name that is not saving or is it the channel/transfered information as well. If it is only the name then I have not seen this problem before on the Illusion and will have to make some tests. It would help if you could e-mail a copy of the show file to me. If it lossing the channel info as well them it may be either a battery problem or an incorrectly seated or possibly even a fault Din ram moduel. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
Carl Ehrhardt Posted November 3, 2003 Author Report Share Posted November 3, 2003 it's only the name... i can send you the show or one of thoses shows... it's in every show we make... but chanaldata, fadingtimes are still saved. well as fare as i think... but i will try it tonight. tell me where i can send the file to. Thanks for your Help! Greatings Carl Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch Link to comment Share on other sites More sharing options...
KWR88 Posted November 3, 2003 Report Share Posted November 3, 2003 Please send the show to krogers@zero88.com As I said I can think of anything that would lose the names only but will have a look at yuor show and get back to you. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
