I am not sure if it has been listed somwhere else already... if not: here is a bug: :cry:
if i name a submaster it doesn't save the information. As soon as i have switched off the desk and switch it on they are no more there. also if i save the show on a disk it doesen't come back unfortunately.
Hope you can fix it :wink:
Greatings
Carl Ehrhardt
Carl Ehrhardt
Technical Director
Kellerbühne St.Gallen
CH-9000 St.Gallen
Switzerland
www.kellerbuehne.ch
First is it only the name that is not saving or is it the channel/transfered information as well.
If it is only the name then I have not seen this problem before on the Illusion and will have to make some tests. It would help if you could e-mail a copy of the show file to me.
If it lossing the channel info as well them it may be either a battery problem or an incorrectly seated or possibly even a fault Din ram moduel.
Keith Rogers
it's only the name... i can send you the show or one of thoses shows... it's in every show we make... but chanaldata, fadingtimes are still saved. well as fare as i think... but i will try it tonight. tell me where i can send the file to.
Thanks for your Help!
Greatings
Carl
Carl Ehrhardt
Technical Director
CH-9000 St.Gallen
Switzerland
www.kellerbuehne.ch
Please send the show to krogers@zero88.com
As I said I can think of anything that would lose the names only but will have a look at yuor show and get back to you.
Keith Rogers
