Memory 0 Timing
NPhillips
Because memory zero is a special memory and not a user-programmable memory, we decided that it would have defined properties and not be editable.
However, it is possible to copy memory zero to another memory number and then edit the delay and fade times as you wish.
You can then use this as your 'blackout memory'.
Bran Media | Myspace
On the memory page, timing should be available for memory 0. This would allow a user to decide whether or not they want "go to cue 0" to be a cut or a fade, or even with a delay!
Illusion Reference No 4715 - Allow Times to be editable in Memory Zero - to be reviewed.
