Because memory zero is a special memory and not a user-programmable memory, we decided that it would have defined properties and not be editable.
However, it is possible to copy memory zero to another memory number and then edit the delay and fade times as you wish.
You can then use this as your 'blackout memory'.
The idea is not to have a black out memory so much as the ability to clear the X fader with grace and poise! Sometimes I would find it useful in rehearsals to say "goto cue 0" and have it fade in a defined time rather than cut.
Lighting Designers!
On the memory page, timing should be available for memory 0. This would allow a user to decide whether or not they want "go to cue 0" to be a cut or a fade, or even with a delay!
Illusion Reference No 4715 - Allow Times to be editable in Memory Zero - to be reviewed.
