When sitting with memory 0 active, and keying [edit blind] the console prompts with "you cannot edit memory 0". I believe that this is wrong, as one should be able to create a cue in blind without having to have an active memory, or having to choose a predetermined memory to work in. The correct result should be that the console say "you cannot edit/save memory 0" in the event one attempts to save memory 0.
I take your point but the only way to Edit Blind at the moment is to select something first, either a memory or a submaster. and then press Edit Blind.
Pressing CHANNEL or GROUP will open the CDW in 'live' mode; what we probably need is a method of opening the CDW in blind mode - would you agree ?
As memory zero is not a user-programmable memory,it was decided that it should not be editable. However, it can be copied to another memory and edited as required.
