mul Posted June 24, 2003 Report Posted June 24, 2003 is it possible to make use of more than the 48 available generic channels on a frog by assigning channels after 48 to subs or something. can one run moving lights from the channels 49+ with a frog and its subs. Quote
K-Nine Posted June 25, 2003 Report Posted June 25, 2003 The specification for the Frog desk is 48 generic (dimmer) channels. Each generic channel may be patched to several DMX addresses (duplicates) but the maximum number of control channels on the Frog is 48. Submasters can only be loaded directly with channel data or transferred memories. If you wish to control moving lights easily and sensibly (ie using HTP for brightness and LTP for the colour, gobo, pan/tilt etc.) then you really need a Fat Frog or one of the larger desks in the Frog series. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
mul Posted June 27, 2003 Author Report Posted June 27, 2003 thanks for the reply, i am only planning on using the frog for moving lights once a year if that and dont have any problems with using bog standard dmx channels on faders to control them aas i have had to do this many times before, is it possible though to do this if nessesary. Equally (if i wanted extra dimmers could i use the frog to control them as well, im no bothered about a bit of extra time being spent while plotting) Cheers Quote
GLX Posted June 28, 2003 Report Posted June 28, 2003 Must be great to have spare time on your hands Quote
K-Nine Posted June 30, 2003 Report Posted June 30, 2003 thanks for the reply, i am only planning on using the frog for moving lights once a year if that and dont have any problems with using bog standard dmx channels on faders to control them aas i have had to do this many times before, is it possible though to do this if nessesary. Equally (if i wanted extra dimmers could i use the frog to control them as well, im no bothered about a bit of extra time being spent while plotting) Cheers You can control moving lights with a Frog but you would to have one preset fader for each DMX channel of the fixture, and they would all be mixed HTP (cf the Fat Frog etc, where moving light control is programmed separately from the generic/dimmer channels and the colour, beam and position parameters are LTP). As I mentioned earlier, the Frog has 48 control channels, so if you had for example an 8 channel moving light then this would use 8 of the preset faders leaving you with 40 channels for conventional dimming. Compare this to the Fat Frog which has 48 generic (dimmer) control channels plus 12 moving lights (up to a max of 288 control channels). Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
LampyLuke Posted March 5, 2007 Report Posted March 5, 2007 Is it possible to use more than 48 generics with a fat frog? Quote
Kirkup_xp Posted March 5, 2007 Report Posted March 5, 2007 You can patch each of the Preset faders to upto 100 duplicates. Alternatively you can also patch <Conventionals> Dimmer as the fixtures to give you 60 unique HTP channels. Again these can be patched to 100 duplicates. Quote Peter Kirkup
