Boggy Posted February 9, 2003 Report Share Posted February 9, 2003 Unsure if this is only on the illusion 120 but when the memory stack is in follow mode it does follow but just moving up one memory at a time with the current memory at the bottom. would it not be better to have the current memory at the top of the screen all the time so i can see what is coming up next? also what are the chances of being able to associate a channel with more than three others so that I can link the all the attributes of am intelligent fixture together. Thanks Chris Quote Link to comment Share on other sites More sharing options...
K-Nine Posted February 10, 2003 Report Share Posted February 10, 2003 Illusion Reference No 4665 - Memories Screen in Follow Mode - the current/next memories should be displayed at the top or middle of the screen rather than the bottom of the screen - Fixed in Version 7 software. The associated channel function was originally designed as a way of 'associating ' a brightness or dimmer channel with a scroller channel. This was then extended to associating up to 4 channels. I can't remember why a maximum of four channels was specified ... probably that's all that will fit into the column on the Assign Channels screen Which Illusion desk are you using ? Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Guest Posted February 11, 2003 Report Share Posted February 11, 2003 Using the 120 desk i guess you might not be able to fit any more nos in the screen yer! but would it be posible to extend this to more atributes? say 6 or 7 maybe? just a thought Chris Quote Link to comment Share on other sites More sharing options...
K-Nine Posted February 12, 2003 Report Share Posted February 12, 2003 ... also what are the chances of being able to associate a channel with more than three others so that I can link the all the attributes of am intelligent fixture together. Illusion Reference No 4699 - Increase the number of channel associations allowed - to be reviewed. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
NPhillips Posted June 3, 2003 Report Share Posted June 3, 2003 So I am having a problem with memories follow on the memories page . When I switch from stay to follow after editing a memory, the screen does not center on the current memory, but further ahead in the stack. Quote Link to comment Share on other sites More sharing options...
LeeStoddart Posted December 11, 2003 Report Share Posted December 11, 2003 So I am having a problem with memories follow on the memories page . When I switch from stay to follow after editing a memory, the screen does not center on the current memory, but further ahead in the stack. This is still a problem in the Novemebr 22nd release (sorry can't remember the release number). It looks to me that when I switch to follow after editing the display shows the last few memories in the show - if I hit go it then scrolls so that the current memory is half visible and the next memory is shown. I also find it annoying that edit takes me into STAY mode and I then have to switch back to FOLLOW - Even if I'm just typing the info text or perhaps changing a time. Quote Lee Stoddart Link to comment Share on other sites More sharing options...
K-Nine Posted December 11, 2003 Report Share Posted December 11, 2003 Point taken, yes there does still appear to be a problem with the positioning of the current/next memories within the memories screen when switching between stay and follow modes after editing. There was a good reason why editing a memory caused the display to switch to Stay Mode, and when I remember what it was I will let you know Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
