editor loaded and presented to outputs in wrong order
if you press edit live whatever was last in the editor is presented to the dmx output then replaced with the memory you are trying to tweak. This unfortunately makes the edit live unuseable as there is a risk of unwanted lighting being flashed up. A workaround is to press edit blind then once the editor has gathered its wits press edit live. Any chance of a reply to this as it has been on here a month now.
