Hello
This has been going on through a lot of releases.
If you have the GM below 100% and wheel a channel up, the channel will go to 100%, then realise it shouldn't be there, if you keep going up it will start to flicker, I assume it is checking things in the wrong order??
Richard
Well spotted ... it only appears to be a problem with the wheel; setting the level directly via the keypad seems to work OK.
Illusion Reference No 4697 - Wheel editing with Grand Master not at 100%.
Bran Media | Myspace
