Guest Tom Warneke Posted June 16, 2003 Report Share Posted June 16, 2003 Howdy. Just got passed a leap from console and 2 studio spot CMY fixtures. how do i program a chase to a submaster? ie....movement (step 1 here, step 2 to there, step 3 over there) and so forth? Cheers. Tom Warneke Production Manager Mainstage Technical Services twarneke@mainstage.s5.com www.mainstage.s5.com Quote Link to comment Share on other sites More sharing options...
K-Nine Posted June 16, 2003 Report Share Posted June 16, 2003 If you want to program movement only chases (ie without recording or affecting any of the other LTP parameters on your fixtures, colours, gobos etc.) first ensure that your desk is set up in Partial program Mode - Desk Setup - Program mode. You then program a chase memory as required and then transfer the memory onto a submaster. If you want a movement effect (rather than plotting each step by hand) this can be programmed directly onto a submaster. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
