Programming Movers on a Leap Frog
Guest Tom Warneke
Howdy.
Just got passed a leap from console and 2 studio spot CMY fixtures.
how do i program a chase to a submaster?
ie....movement (step 1 here, step 2 to there, step 3 over there) and so forth?
Cheers.
Tom Warneke
Production Manager
Mainstage Technical Services
twarneke@mainstage.s5.com
www.mainstage.s5.com
If you want to program movement only chases (ie without recording or affecting any of the other LTP parameters on your fixtures, colours, gobos etc.) first ensure that your desk is set up in Partial program Mode - Desk Setup - Program mode.
You then program a chase memory as required and then transfer the memory onto a submaster.
If you want a movement effect (rather than plotting each step by hand) this can be programmed directly onto a submaster.
