dominicgross Posted June 4, 2003 Report Posted June 4, 2003 getting a couple of mac 500 for next week, been playing with our rented fatty, This may be a no brainer to you binary flicking, cable crimping types, but: How do i set up a constant gobo rotation? - You know break up gobo rotates and looks really kool? I am having no luck. PLEASE HELP. Cheers Quote Dom Gross
richard Posted June 4, 2003 Report Posted June 4, 2003 Please note, the following is from memory, and may be for a vari*lite, but I think it works for a mac too: The rotating/indexing gobo wheel has two sets of ranges on the one channel - ie you go through the gobo wheel on the control channel twice, the first time the gobo will index, the second time it will rotate. ie: step 1 : gobo 1 index step 2 : gobo 2 index step 3 : gobo 3 index step 4 : gobo 1 rotate step 5 : gobo 2 rotate step 6 : gobo 3 rotate (I know there are more that three gobos, but hopefully this explains a bit) It may not seem very clear, but the dmx allocation thing in the manual should help.. Richard Quote
K-Nine Posted June 5, 2003 Report Posted June 5, 2003 According to the DMX data I have on the MAC 500: Channel 5 is the Rotating Gobo Selection - To select a gobo for indexing set a value in the range 0-155; to select a gobo for rotation, set a value between 156-255. This parameter is displayed as "RotGobo" on the wheel LCD. Channel 6 is the Rotating Gobo Index/Rotation - 0-2 is static, 3-127 is CCW rotation from slow to fast, 128-251 is CW rotation fast to slow and 252-255 is static. This parameter is displayed as "Ind/Rot" on the wheel LCD. Happy spinning Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
