Memories
Guest Larson
Guest Larson
Hi frogers.
If I have programmed for ex. 87 memories, I am running memory nr 5 (or whatever) and all of a sudden want to quick go to nr 75(for ex).
Do I have to push the "+" button 70 times or is there any shortcut?
Its not always from memory nr 5 to 75. Next time it could be nr 5 to 66 or nr 44 to 13(or any given combination).
Is there any shortcut to move faster in the memory bank?
best reg./ J Larson
The above post is correct; the quickest way to move to a specified memory number is via the external keyboard.
Note that you may need to press the memories button first if the cursor is not currently on the Next memory number field on the LCD.
Entry of numeric data via an external keyboard was added in Version 7.5 software.
Bran Media | Myspace
