Running a scene and chase
Guest Lee B
Guest Lee B
I've just purchased a Fat Frog desk and was wondering when your running a scene can you run a chase setup over the top of that - or can you only do that by adding a chase as a submaster and fading it up at the given time?
Best Wishes
Lee
If you set the desk up in Partial Program mode, you can program a scene memory, then program the next memory in the stack as a chase. If you only record those fixtures and attributes you wish to chase then the other fixtures should remain at their previous values from the scene.
You can also program a chase and transfer it onto a submaster and then raise the submaster when required.
Bran Media | Myspace
