Moving effects: Set speed to 0
Guest pollywog
Is there an other way to set the speed parameter to zero as trying to catch it with the wheel?
The movement effect parameters (as with all other fixture parameters) can only be adjusted via the control wheels, but I believe that if you home position for a fixture, the movement effect parameters will also be reset to their default values.
Bran Media | Myspace
