I have some problem when I programming movingheads.
I set my levels and program them into memories and then transfer them into submasters. I do the same thing with generics and others moving lights and put them on different memories and submasters.
When I´m finnished with the programming an want to test it I live.
I put the submaster on with the movingheads and they do what is programming, ok.
But when I put the next submaster on whith generics and other moving heads and have the first on too, the first submasters moving heads go to "home".
I have try to have the desk in booth partial and full mode.
Is It something with tagging fixture?
Help!!
Ok, you must first select partial mode before starting to program any of the memories.
Second while programming keep the playback X fader down.
When you program the moving light into a memory only those lights that that you alter a parameter ( which become auto tagged) or manual tag by holding the fixture button down for a few seconds will be programmed. Tagged fixtures can be identified by the yellow LED on the fixture button flashing.
If you move a fixture parameter by mistake that you do not want to include in the programme simply hold the fixture button down until the yellow LED starts to flash.
Before pressing the program button just check which fixtures are tagged.
Keith Rogers
