Copying fixture tags
Guest Eddie Stephens
How do you copy fixture tags/LTP parameters from one memory to another already programmed one? so you can preset them ready for the next memory in a stack:?:
I'd suggest the following:
- Transfer Memory 'B' (the one you want to copy the LTPs from) to a spare submaster.
- Edit Memory 'A' (the one you want the LTPs recorded into). Whilst in edit mode, push up the submaster with memory 'B' on it, then bring it back down again. This will cause all the LTPs from Memory 'B' to be output, and hence be stored in Memory 'A' when you leave edit mode.
Other suggestions welcome!
